I am trying to set up pop ups of environmental data which uses the label in the domain rather than the code value. At the moment I have been setting up the pop ups using else if statements.
e.g.
var Type = $feature.lifestage;
if (Type == 'A') {Type = 'adult';}
else if (Type == 'Lva') {Type = 'larvae';}
else if (Type == 'E') {Type = 'egg';}
return Type;
However I need to do the same thing for species data using a domain of plant lists which is several thousand rows long so can't use the same code as above. I'm sure there must be a simple solution that I am hoping someone can share with me. Example subset of domain is below.
| CODE | DESC |
| NBNSYS0200001285 | Abelia |
| NBNSYS0000139224 | Abies (Firs) |
| NHMSYS0000455513 | Abies alba (European Silver-fir) |
| NBNSYS0000042419 | Abies amabilis |
| BMF | Abies bornmuelleriana (Trojan Fir) |
| NBNSYS0000034340 | Abies cephalonica (Greek Fir) |
| NHMSYS0021109850 | Abies fraseri (Fraser Fir) |
| NHMSYS0000455520 | Abies grandis (Giant Fir) |
| NBNSYS0000034011 | Abies nordmanniana (Caucasian Fir) |
| NBNSYS0000140832 | Abies procera (Noble Fir) |
| NBNSYS0000139234 | Abutilon |
| NHMSYS0100000348 | Abutilon theophrasti (Velvetleaf) |
| NBNSYS0000139235 | Acacia (Australian Blackwood) |
| NHMSYS0000455529 | Acacia melanoxylon (Australian Blackwood) |
| NBNSYS0000139236 | Acaena |
| NBNSYS0000003391 | Acaena anserinifolia (Bronze Pirri-pirri-bur) |
| NBNSYS0000014912 | Acaena anserinifolia x inermis (Pirri-Pirri-Bur) |
