Hello Community; I have been using the Divide/Clip under modify option to create interior polygon holes within a larger polygon. Using the input and output selections to cut a hole, an outline polygon is created within that larger feature as part of that feature. The input interior feature has to be deleted from the rows of features within the layer in question in order to "see through" the cut hole. But when adjusting the width properties of the outline polygon to the large feature the interior polygon hole line does not respond. Only the original large feature outline responds to changes. Any trick around this? I am using Pro 2.9.5 in W 10. Thanks, Dave
