So I have a model builder code which works fine as intended.
The only thing I want to add to it is an if statement at the beginning of the code in line 24. That if true then don't run the rest of the script and just print script ran successfully. But if it's false then run the rest of the code as is.
Condition:
If in Grants_xlsx X is not NULL then run skip the rest of the code and run the last print statement.
Code:
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2024-02-21 14:43:11
import arcpy
import pandas as pd
def Model(): # Model
# To allow overwriting outputs change overwriteOutput option to True.
arcpy.ImportToolbox(r"c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Conversion Tools.tbx")
arcpy.ImportToolbox(r"c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Data Management Tools.tbx")
DimTriCountyCities = "O:\\bla\\Ed\\GeocodeProject\\ModelGeodatabase.gdb\\DimTriCountyCities"
Grants_xlsx = r"\\path\Grants.xlsx"
BrowardCompositeLocator = "https://bla/Locator"
DimTriCountyCities_2_ = "O:\\path\\ModelGeodatabase.gdb\\DimTriCountyCities"
DimTriCountyCities_4_ = "O:\\path\\ModelGeodatabase.gdb\\DimTriCountyCities"
# Process: Excel To Table (Excel To Table) (conversion)
Grants_ExcelToTable = "O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable"
arcpy.conversion.ExcelToTable(Input_Excel_File=Grants_xlsx, Output_Table=Grants_ExcelToTable, Sheet="Grants")
# Process: Export Table (Export Table) (conversion)
Grants_Filtered = "O:\\path\\ModelGeodatabase.gdb\\Grants_Filtered"
arcpy.conversion.ExportTable(in_table=Grants_ExcelToTable, out_table=Grants_Filtered, where_clause="X IS NULL And Street_Address <> ''", field_mapping="Grant_Type \"Grant Type\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Grant_Type,0,255;Grant_Sub_Category \"Grant Sub-Category\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Grant_Sub_Category,0,255;Program_Area \"Program Area\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Program_Area,0,255;Name \"Name\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Name,0,255;District \"District\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,District,0,255;Street_Address \"Street Address\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Street_Address,0,255;City \"City\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,City,0,255;Postal_Code \"Postal Code\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Postal_Code,0,255;Funded_Amount \"Funded Amount\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Funded_Amount,-1,-1;website \"website\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,website,0,255;Fiscal_Year \"Fiscal Year\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Fiscal_Year,-1,-1")
# Process: Geocode Addresses (Geocode Addresses) (geocoding)
Grants_Filtere_GeocodeAddres = "O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres"
arcpy.geocoding.GeocodeAddresses(in_table=Grants_Filtered, address_locator=BrowardCompositeLocator, in_address_fields="Address Street_Address VISIBLE NONE;Address2 <None> VISIBLE NONE;Address3 <None> VISIBLE NONE;Neighborhood <None> VISIBLE NONE;City City VISIBLE NONE;County <None> VISIBLE NONE;State <None> VISIBLE NONE;ZIP Postal_Code VISIBLE NONE;ZIP4 <None> VISIBLE NONE;Country <None> VISIBLE NONE", out_feature_class=Grants_Filtere_GeocodeAddres, output_fields="MINIMAL")
# Process: Export Table (2) (Export Table) (conversion)
Grants_Unmatched = "O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched"
arcpy.conversion.ExportTable(in_table=Grants_Filtere_GeocodeAddres, out_table=Grants_Unmatched, where_clause="Status = 'U'", field_mapping="Grant_Type \"Grant Type\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Grant_Type,0,255;Grant_Sub_Category \"Grant Sub-Category\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Grant_Sub_Category,0,255;Program_Area \"Program Area\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Program_Area,0,255;Name \"Name\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Name,0,255;District \"District\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,District,0,255;Street_Address \"Street Address\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Street_Address,0,255;City \"City\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,City,0,255;Postal_Code \"Postal Code\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Postal_Code,0,255;Funded_Amount \"Funded Amount\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Funded_Amount,-1,-1;website \"website\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,website,0,255;Fiscal_Year \"Fiscal Year\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Fiscal_Year,-1,-1;Status \"Status\" true true true 1 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Status,0,1;Score \"Score\" true true true 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Score,-1,-1")
# Process: Join Field (Join Field) (management)
Grants_Unmatched_2_ = arcpy.management.JoinField(in_data=Grants_Unmatched, in_field="City", join_table=DimTriCountyCities_2_, join_field="CITY", fields=["X", "Y"])[0]
# Process: Export Table (3) (Export Table) (conversion)
Grants_UN_Updated = "O:\\path\\ModelGeodatabase.gdb\\Grants_UN_Updated"
arcpy.conversion.ExportTable(in_table=Grants_Unmatched_2_, out_table=Grants_UN_Updated, field_mapping="Grant_Type \"Grant Type\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Grant_Type,0,255;Grant_Sub_Category \"Grant Sub-Category\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Grant_Sub_Category,0,255;Program_Area \"Program Area\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Program_Area,0,255;Name \"Name\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Name,0,255;District \"District\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,District,0,255;Street_Address \"Street Address\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Street_Address,0,255;City \"City\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,City,0,255;Postal_Code \"Postal Code\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Postal_Code,0,255;Funded_Amount \"Funded Amount\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Funded_Amount,-1,-1;website \"website\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,website,0,255;Fiscal_Year \"Fiscal Year\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Fiscal_Year,-1,-1;X \"X\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,X,-1,-1;Y \"Y\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Y,-1,-1;Status \"Status\" true true true 1 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Status,0,1;Score \"Score\" true true true 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Unmatched,Score,-1,-1")
# Process: XY Table To Point (XY Table To Point) (management)
Grants_UN_XY = "O:\\path\\ModelGeodatabase.gdb\\Grants_UN_XY"
arcpy.management.XYTableToPoint(in_table=Grants_UN_Updated, out_feature_class=Grants_UN_XY, x_field="X", y_field="Y", coordinate_system="GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision")
# Process: Export Table (4) (Export Table) (conversion)
Grants_NoAddress = "O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress"
arcpy.conversion.ExportTable(in_table=Grants_ExcelToTable, out_table=Grants_NoAddress, where_clause="Street_Address = ''", field_mapping="Grant_Type \"Grant Type\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Grant_Type,0,255;Grant_Sub_Category \"Grant Sub-Category\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Grant_Sub_Category,0,255;Program_Area \"Program Area\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Program_Area,0,255;Name \"Name\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Name,0,255;District \"District\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,District,0,255;Street_Address \"Street Address\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Street_Address,0,255;City \"City\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,City,0,255;Postal_Code \"Postal Code\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Postal_Code,0,255;Funded_Amount \"Funded Amount\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Funded_Amount,-1,-1;website \"website\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,website,0,255;Fiscal_Year \"Fiscal Year\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Fiscal_Year,-1,-1;Status \"Status\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Status,0,255;Score \"Score\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Score,-1,-1")
# Process: Join Field (2) (Join Field) (management)
Grants_NoAddress_3_ = arcpy.management.JoinField(in_data=Grants_NoAddress, in_field="City", join_table=DimTriCountyCities_4_, join_field="CITY", fields=["X", "Y"])[0]
# Process: Export Table (5) (Export Table) (conversion)
Grants_NA_Updated = "O:\\path\\ModelGeodatabase.gdb\\Grants_NA_Updated"
arcpy.conversion.ExportTable(in_table=Grants_NoAddress_3_, out_table=Grants_NA_Updated, field_mapping="Grant_Type \"Grant Type\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Grant_Type,0,255;Grant_Sub_Category \"Grant Sub-Category\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Grant_Sub_Category,0,255;Program_Area \"Program Area\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Program_Area,0,255;Name \"Name\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Name,0,255;District \"District\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,District,0,255;Street_Address \"Street Address\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Street_Address,0,255;City \"City\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,City,0,255;Postal_Code \"Postal Code\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Postal_Code,0,255;Funded_Amount \"Funded Amount\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Funded_Amount,-1,-1;website \"website\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,website,0,255;Fiscal_Year \"Fiscal Year\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Fiscal_Year,-1,-1;X \"X\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,X,-1,-1;Y \"Y\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Y,-1,-1;Status \"Status\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Status,0,255;Score \"Score\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_NoAddress,Score,-1,-1")
# Process: XY Table To Point (2) (XY Table To Point) (management)
Grants_NAU_XY = "O:\\path\\ModelGeodatabase.gdb\\Grants_NAU_XY"
arcpy.management.XYTableToPoint(in_table=Grants_NA_Updated, out_feature_class=Grants_NAU_XY, x_field="X", y_field="Y", coordinate_system="GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision")
# Process: Export Table (6) (Export Table) (conversion)
Grants_WithXY = "O:\\path\\ModelGeodatabase.gdb\\Grants_WithXY"
arcpy.conversion.ExportTable(in_table=Grants_ExcelToTable, out_table=Grants_WithXY, where_clause="X IS NOT NULL And Street_Address <> ''", field_mapping="Grant_Type \"Grant Type\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Grant_Type,0,255;Grant_Sub_Category \"Grant Sub-Category\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Grant_Sub_Category,0,255;Program_Area \"Program Area\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Program_Area,0,255;Name \"Name\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Name,0,255;District \"District\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,District,0,255;Street_Address \"Street Address\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Street_Address,0,255;City \"City\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,City,0,255;Postal_Code \"Postal Code\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Postal_Code,0,255;Funded_Amount \"Funded Amount\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Funded_Amount,-1,-1;website \"website\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,website,0,255;Fiscal_Year \"Fiscal Year\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Fiscal_Year,-1,-1;X \"X\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,X,-1,-1;Y \"Y\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Y,-1,-1;Status \"Status\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Status,0,255;Score \"Score\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_ExcelToTable,Score,-1,-1")
# Process: XY Table To Point (3) (XY Table To Point) (management)
Grants_WithXY_XY = "O:\\path\\ModelGeodatabase.gdb\\Grants_WithXY_XY"
arcpy.management.XYTableToPoint(in_table=Grants_WithXY, out_feature_class=Grants_WithXY_XY, x_field="X", y_field="Y", coordinate_system="GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision")
# Process: Export Features (Export Features) (conversion)
Grants_Matched = "O:\\path\\ModelGeodatabase.gdb\\Grants_Matched"
arcpy.conversion.ExportFeatures(in_features=Grants_Filtere_GeocodeAddres, out_features=Grants_Matched, where_clause="Status = 'M' Or Status = 'T'", field_mapping="Status \"Status\" true true true 1 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Status,0,1;Score \"Score\" true true true 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Score,-1,-1;Grant_Type \"Grant Type\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Grant_Type,0,255;Grant_Sub_Category \"Grant Sub-Category\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Grant_Sub_Category,0,255;Program_Area \"Program Area\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Program_Area,0,255;Name \"Name\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Name,0,255;District \"District\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,District,0,255;Street_Address \"Street Address\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Street_Address,0,255;City \"City\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,City,0,255;Postal_Code \"Postal Code\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Postal_Code,0,255;Funded_Amount \"Funded Amount\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Funded_Amount,-1,-1;website \"website\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,website,0,255;Fiscal_Year \"Fiscal Year\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Filtere_GeocodeAddres,Fiscal_Year,-1,-1")
# Process: Calculate Geometry Attributes (Calculate Geometry Attributes) (management)
Grants_Matched_2_ = arcpy.management.CalculateGeometryAttributes(in_features=Grants_Matched, geometry_property=[["X", "POINT_X"], ["Y", "POINT_Y"]], coordinate_system="GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]]")[0]
# Process: Export Features (3) (Export Features) (conversion)
Grants_Final = "O:\\path\\ModelGeodatabase.gdb\\Grants_Final"
arcpy.conversion.ExportFeatures(in_features=Grants_Matched_2_, out_features=Grants_Final, field_mapping="Grant_Type \"Grant Type\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Grant_Type,0,255;Grant_Sub_Category \"Grant Sub-Category\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Grant_Sub_Category,0,255;Program_Area \"Program Area\" true true false 255 Text 0 0,First,#,O:\\path\ModelGeodatabase.gdb\\Grants_Matched,Program_Area,0,255;Name \"Name\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Name,0,255;District \"District\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,District,0,255;Street_Address \"Street Address\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Street_Address,0,255;City \"City\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,City,0,255;Postal_Code \"Postal Code\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Postal_Code,0,255;Funded_Amount \"Funded Amount\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Funded_Amount,-1,-1;website \"website\" true true false 255 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,website,0,255;Fiscal_Year \"Fiscal Year\" true true false 4 Long 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Fiscal_Year,-1,-1;X \"X\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,X,-1,-1;Y \"Y\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Y,-1,-1;Status \"Status\" true true false 1 Text 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Status,0,1;Score \"Score\" true true false 8 Double 0 0,First,#,O:\\path\\ModelGeodatabase.gdb\\Grants_Matched,Score,-1,-1")
# Process: Append (Append) (management)
if Grants_Final and Grants_NAU_XY and Grants_UN_XY and Grants_WithXY_XY:
Updated_Target_Dataset = arcpy.management.Append(inputs=[Grants_UN_XY, Grants_NAU_XY, Grants_WithXY_XY], target=Grants_Final)[0]
# Process: Table To Excel (Table To Excel) (conversion)
Grants_xlsx_3_ = "\\path\Grants.xlsx"
arcpy.conversion.TableToExcel(Input_Table=[Updated_Target_Dataset], Output_Excel_File=Grants_xlsx_3_, Use_field_alias_as_column_header="ALIAS")
if __name__ == '__main__':
# Global Environment settings
with arcpy.EnvManager(scratchWorkspace="O:\\path\\ModelGeodatabase.gdb", workspace="O:\\path\\ModelGeodatabase.gdb"):
Model()
print("Script ran successfully")
