what to edit in the following code to make the facade picture appear correctly after the split ?
<SPAN class="operator token">/</SPAN><SPAN class="operator token">**</SPAN>
<SPAN class="operator token">*</SPAN> File<SPAN class="punctuation token">:</SPAN> comp_split<SPAN class="punctuation token">.</SPAN>cga
<SPAN class="operator token">*</SPAN> Created<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5</SPAN> Oct <SPAN class="number token">2019</SPAN> <SPAN class="number token">06</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">28</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">38</SPAN> GMT
<SPAN class="operator token">*</SPAN> Author<SPAN class="punctuation token">:</SPAN> Bilal Mustafa
<SPAN class="operator token">*</SPAN><SPAN class="operator token">/</SPAN>
version <SPAN class="string token">"2018.1"</SPAN>
<SPAN class="keyword token">import</SPAN> gen_Facade_AdvancedFacade3 <SPAN class="punctuation token">:</SPAN><SPAN class="string token">"/شارع السهل/rules/gen_Facade_goolge2_cropped.cga"</SPAN>
attr height <SPAN class="operator token">=</SPAN> <SPAN class="number token">10</SPAN>
attr groundfloor_height<SPAN class="operator token">=</SPAN><SPAN class="number token">5</SPAN>
attr floor_height<SPAN class="operator token">=</SPAN><SPAN class="number token">3</SPAN>
Lot <SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN>
extrude<SPAN class="punctuation token">(</SPAN>height<SPAN class="punctuation token">)</SPAN>
comp<SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN> Base <SPAN class="operator token">|</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN> Roof <SPAN class="operator token">|</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">:</SPAN> AA <SPAN class="operator token">|</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">:</SPAN> BB
<SPAN class="operator token">|</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">:</SPAN> CC <SPAN class="punctuation token">}</SPAN>
AA <SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN>
split<SPAN class="punctuation token">(</SPAN>y<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> groundfloor_height <SPAN class="punctuation token">:</SPAN> Floor<SPAN class="punctuation token">(</SPAN>split<SPAN class="punctuation token">.</SPAN>index<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">//</SPAN> Groundfloor
<SPAN class="operator token">|</SPAN> floor_height <SPAN class="punctuation token">:</SPAN> Floor<SPAN class="punctuation token">(</SPAN>split<SPAN class="punctuation token">.</SPAN>index<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">//</SPAN> First Floor
<SPAN class="operator token">|</SPAN> floor_height <SPAN class="punctuation token">:</SPAN> Floor<SPAN class="punctuation token">(</SPAN>split<SPAN class="punctuation token">.</SPAN>index<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">//</SPAN> Second Floor
<SPAN class="operator token">|</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="operator token">~</SPAN>floor_height <SPAN class="punctuation token">:</SPAN> Floor<SPAN class="punctuation token">(</SPAN>split<SPAN class="punctuation token">.</SPAN>index<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="operator token">*</SPAN> <SPAN class="operator token">//</SPAN> Mid Floors
<SPAN class="operator token">|</SPAN> floor_height <SPAN class="punctuation token">:</SPAN> Floor<SPAN class="punctuation token">(</SPAN><SPAN class="number token">999</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">//</SPAN> Top Floor<SPAN class="punctuation token">,</SPAN> indexed <SPAN class="keyword token">with</SPAN> <SPAN class="number token">999</SPAN>
<SPAN class="operator token">|</SPAN> <SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">:</SPAN> s<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'1,'</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.3</SPAN><SPAN class="punctuation token">)</SPAN> LedgeAsset<SPAN class="punctuation token">}</SPAN> <SPAN class="operator token">//</SPAN> The top ledge just below the roof
facade
facade<SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN>
comp<SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="punctuation token">:</SPAN>gen_Facade_AdvancedFacade3<SPAN class="punctuation token">.</SPAN>Facade<SPAN class="punctuation token">}</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
