After I upgraded from 2023.3 to 2023.3.1, ArcGIS Monitor wouldn't fully start. I could see processes running in Task Manager but I the UI wasn't responsive on ports 30443 or 30080 and nothing was bound to those ports when I checked using netstat.
This is how I fixed it, but I'm not completely confident this hasn't left things in an inconsistent state.
I uninstalled ArcGIS Monitor, backed up C:\Program Files\ArcGIS\Monitor and C:\Users\[serviceuser]\AppData\Local\ESRI\ArcGISMonitor\config-store-server, then reinstalled 2023.3.1. Things lit up after that, but of course I'd lost config-store-server which among other things includes user accounts, SSL certificates, etc.
I tried restoring config-store-server to the backed up version and it stopped working again. I took a copy of the fresh config-store-server, rolled back to a snapshot just prior to the uninstall, and replaced the original config-store-server with the fresh copy. This caused the original installation to start working, so the problem was narrowed down to config-store-server.
After some trial and error, I found that replacing .env and ssl\ssl.pfx with copies from the fresh install was enough to get the original installation working again. At that point I was prompted to go through /arcgis/monitor/setup to enter exiting credentials but everything was intact after that, though I will have to reconfigure the SSL certificate.
EDIT: I also found an .env.lock.STALE.STALE file in the original installation which didn't appear to have any impact on whether Monitor started or not.
So, the bug report in summary:
- Something happened (or didn't happen) to config-store-server during the upgrade from 2023.3 to 2023.3.1.
- Replacing .env and ssl\ssl.pfx with fresh copies is the minimum to get ArcGIS Monitor to start again.
And my questions:
Is this fix sufficient or will it have potentially made things inconsistent? Could it have been fixed more appropriately?
Tristan
