Our pop-ups work as intended in Map Viewer and on Field Maps. Those same pop-ups close out when using them in Experience Builder.
An example would be when we click on a water valve, the pop-ups include the valve, the water lines, etc. When the pop-up comes up, everything is fine. As soon as you attempt to go to the next pop-up, it shuts the window down. This only happens in Experience Builder. Those same pop-ups in other apps work just as intended.
Has anyone else come across this and found a solution?
Thanks!
