Hello everybody,
I am using the ArcGIS API for JavaScript version 4.24. I have created an HGIS (Historical Geographic Information System) application for the tribes of Arabia. My map consists of multiple genealogically layered overlays. When I click on a territory of a tribe, I can retrieve a list of successive parent tribes to which it belongs in the form of clickable buttons, and this works perfectly.
On the buttons for the parent tribes, I intended to display the "Name" attribute, which is in English and Arabic. It displayed correctly with test data, but after publishing my data to ArcGIS Online, I am unable to access all my attributes. The console log only provides the ID and the "Name_en" attribute. However, using the 'PopupTemplate' I can retrieve all attributes.
Below is a snippet of my code, along with screenshots showing the list display with the "Name_en" attribute and the empty list display when I use the "Name" attribute.
let poptemp;
// Create PopupTemplate for displaying information
poptemp = new PopupTemplate({
title: "{Name}",
content: [{
type: "fields",
fieldInfos: [{
fieldName: "Name_ar",
label: "Name_ar"
fieldName: "Name_en",
label: "Name_en"
fieldName: "Wiki_ar_link",
label: "Wiki_ar_link"
fieldName: "Wiki_en_link",
label: "Wiki_en_link"
let Mygraphic = new Graphic({
popupTemplate: poptemp
const Mycontainer = document.getElementById("gridDiv");
Mycontainer.innerHTML = "";
const listNode = document.getElementById("new_graphic");
let feature_1 = new Feature({
graphic: Mygraphic,
view: view,
container: Mycontainer
let highlight;
let results;
let result;
// Event handler for list item clicks
function onListClickHandler(event) {
const target = event.target;
const resultId = target.getAttribute("data-result-id");
result = resultId && results && results[parseInt(resultId, 10)];
view.whenLayerView(result.graphic.layer).then(function (layerView) {
if (result && results.length > 0) {
highlight && highlight.remove();
view
.goTo(result.graphic.geometry.extent.expand(1))
.then(function () {
result.graphic.layer.popupTemplate = poptemp;
feature_1.graphic = result.graphic;
highlight = layerView.highlight(result.graphic);
handleClick(result);
} else {
feature_1.graphic = graphic;
// Function to update the displayed list
function updateList(results) {
const fragment = document.createDocumentFragment();
results = results.reverse();
results.forEach(function (result, index) {
const attributes = result.graphic.attributes;
const li = document.createElement("li");
li.classList.add("panel-result");
li.tabIndex = index;
li.setAttribute("data-result-id", index);
li.textContent = attributes.Name;
fragment.appendChild(li);
listNode.innerHTML = "";
listNode.appendChild(fragment);
listNode.style.display = "block";
listNode.addEventListener("click", onListClickHandler);
Thank you in advance for your help.
Karim
