I'm working on converting a map app from Leaflet.js to the Esri JS API (4.x). I have a field that contains the URL to an image. However, not every record has an image.
I was planning on using the code below to add the image to the pop-up. However, I was wondering if there is a way to control the pop-up logic so that the image only appears if the value in the field is not false (technically null)?
Thanks for the help.
<SPAN class="keyword token">const</SPAN> popupTemplate <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Survey Location: <strong>{expression/display-location}</strong>'</SPAN><SPAN class="punctuation token">,</SPAN>
expressionInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'display-location'</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Location'</SPAN><SPAN class="punctuation token">,</SPAN>
expression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"DefaultValue($feature.Loc_ID ,'Not Defined')"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">{</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'round-latitude'</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Latitude'</SPAN><SPAN class="punctuation token">,</SPAN>
expression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Round($feature.LAT, 3)"</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'round-longitude'</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Longitude'</SPAN><SPAN class="punctuation token">,</SPAN>
expression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Round($feature.LONG, 3)"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'format-area'</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Area Surveyed (sq. ft.)'</SPAN><SPAN class="punctuation token">,</SPAN>
expression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Text($feature.Area, '#,###')"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'fields'</SPAN><SPAN class="punctuation token">,</SPAN>
fieldInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'expression/round-latitude'</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'expression/round-longitude'</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'expression/format-area'</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'media'</SPAN><SPAN class="punctuation token">,</SPAN>
mediaInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Survey Location: {expression/display-location}'</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'image'</SPAN><SPAN class="punctuation token">,</SPAN>
value<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
sourceURL<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'{IMG}'</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
