Hello! I am working on my master thesis and want to analyze the density of the bicycle network of a relatively big town in Germany (ca. 380.000 people). I use data from OSM that I extracted with Overpass Turbo. The angular unit of the file was automatically in degree because of the GCS so I converted everything to a suitable PCS with meters.
Now the problem: I tested a lot with the line density tool to create an index like the papers my work is based on did. I chose an output cell size of 100 (to get 100x100m) and a search radius of 250 (that is based on the papers). As Area units I picked square map units and also chose the correct Output Coordinate System in the Environments part of the tool.
The results that I get from that are confusing to me. They range from 0,001 to 0,024. In my understanding that should be meters/squaremeters which is obviously way too low for a dense urban area. I tested a lot of different things but I just don't get what is going wrong here.
The mentioned papers say they used Math tools to make the values easier to interpretate but I don't know what they mean by that. Meters/Squaremeters should be the output and that is perfectly interpretable.
I hope someone can save me here, because I am really lost.. Thank you very much in advance!
Kind regards,
Ole
