I'm working in Arcgis pro and have created a utility network. I would like to write a constraint rule. Our feature class "Structure Line" has two asset groups: "The rule should automatically check if a "Trasse" and a "Schutzrohr" intersect. If that's the case, the rule should check if they have the same value in the "Network Level" column of the attribute table. If not, an error message should appear.
