I'm wondering if this is something with our specific app or not so I'm reaching out here to see if anyone else has seen this.
On devices with Android 14 we are seeing that if you have our app open with the map visible, switch to another app for minimum 10-15s (without fully closing our app), and then go back to our app, you can't interact with the map anymore (can't pan, click, zoom). If you rotate the device so it re-renders, things are back again.
We are running 100.15.1 in production, and it is also happening with 100.15.4. It is not happening with the iOS version of our app.
Edit: It's worth mentioning that other UI elements in our app (e.g. buttons on top of the map) work after switching back to the app, it's just the map that doesn't accept interactions anymore.
Edit2: We haven't been able to reproduce in simulator thus far, only on physical devices.
