Hey all,
I have a user that forgot to sync his data from Field Maps and the replicas have been disconnected in the meantime. The service contains a couple of feature classes and 4 tables, everything related to each other.
I have downloaded a copy of the service from AGOL and based on this article Preserving a GlobalID while moving data between Fe... - Esri Community, I have copied the data from this service to a 'Mobile Geodatabase'.
When I try to append the unsynced data, I get the following insert error 000597: Failed to insert input record with FeatureID <value>.—ArcGIS Pro | Documentation.
Looking for the correct methodology to append this data?
