I have a raster dataset that cannot be deleted.
Things I have tried:
A. R-Click the raster dataset --> Select Delete --> Are you sure --> Yes --> ArcGIs says, "Deleting..." --> I hit Refresh and the raster reappears
B. Run the Delete geoprocessing tool - give error WARNING 000110: \\gisshare\GISRaster_Services\GISRasterServices.gdb\RasterComposite does not exist.
C. Rebooted server then tried A again then rebooted a second time before checking for its existence
And after some drive mapping wizardry I was able to delete it from a different computer using ArcCatalog (Arc Desktop was not installed on the server which houses the file geodatabase that held the offending Raster Dataset.)
At this point I guess I'm posting this in case someone else comes across this problem.
