Hey all,
Not sure if this would be best placed inside of an Idea instead, but I've worked with databases for a decent amount of time and I find myself confused on the limitations of the ArcGIS Geodatabase Administration that is currently present.
Why are we limited to needing to Version data in order to create a one way replication. In my mind, there is no reason why unnecessary fields need to be added that will not have any pertinent use, I am replicating from an editable database, to a read-only geodatabase which will not be edited in any way by the receiving party.
Archiving is not enabled, versioning is not enabled, and the data being replicated is not read-only. Why is there this limitation?
Thank you in advance,
Cody
