I'm using postman to prepare a request.
Below is an example of a successful routing between Orlando. FL to Tallahassee FL.
GET https://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World/solve?token={{token}}&f=json&stops=-81.3753552,28.5387011; -84.3078194,30.4382702
Now I want to add additional parameters shown here: Direct request—ArcGIS REST APIs | ArcGIS Developers.
1) restrictionAttributeNames
2) attributeParameterValues
These should be something like:
"restrictionAttributeNames":"Height Restriction, Width Restriction, Weight Restriction, Weight per Axle Restriction, Length Restriction, Kingpin to Rear Axle Length Restriction, Axle Count Restriction, Use Preferred Truck Routes",
"attributeParameterValues": [
"attributeName": "Height Restriction",
"parameterName": "Vehicle Height (meters)",
"value": 3.6576
"attributeName": "Width Restriction",
"parameterName": "Vehicle Width (meters)",
"value": 3.6576
"attributeName": "Weight Restriction",
"parameterName": "Vehicle Weight (kilograms)",
"value": 10000
"attributeName": "Weight per Axle Restriction",
"parameterName": "Vehicle Weight per Axle (kilograms)",
"value": 1500
"attributeName": "Length Restriction",
"parameterName": "Vehicle Length (meters)",
"value": 15.24
"attributeName": "Kingpin to Rear Axle Length Restriction",
"parameterName": "Vehicle Kingpin to Rear Axle Length (meters)",
"value": 15.24
"attributeName": "Axle Count Restriction",
"parameterName": "Number of Axles",
"value": 7
"attributeName": "Use Preferred Truck Routes",
"parameterName": "Restriction Usage",
"value": "Prefer_High"
But I can't seem to format these properly into the request.
1) Am I doing this right?
2) Am I forgetting some other parameter?
3) What should the request look like?
Please help! Thanks!
