Hey all,
Big edit, I was initially thinking that these columns caused the issue, but I have now found that Archiving is doing the work that's causing the issues, these columns are creating my issues:
Recently, I worked with an ESRI Tech in order to enable versioning on my dataset, that has completely toppled our production network seemingly by just adding these few columns to all the tables. (Not ESRI Tech's fault)
I am currently in the stages of grief and am working through removing these versioned columns from the tables that are currently equipped with them. I was curious if anyone knows what exact columns are added when versioned data is enabled? I want to be sure that I'm removing the correct columns and returning my data to production, as with a few tests, once a few columns are removed, the table becomes active once more, but I haven't found which exact columns are the ones.
I was curious if these may be it?
Thank you in advance!
Cody
