Hi all- I've set up our UN, cleared all the errors, and started playing with subnetworks. Thinking I'd start simple with a high level pressure zone, with one pump station feeding it and one pressure reducing valve ending it. I made the Pumpstation the controller and ran the pressure zone trace. Unexpectedly, the trace ran right through the regulator valve and selected 2 full pressure zones. Oddly the trace did stop at the check valves. I confirmed that both valves and connected pipes have the correct terminal settings. It's also possible that the trace went both directions from the pump station, but this seems less likely. Anyway, I would expect a preconfigured pressure trace to stop at a PR valve? Or do I need to make that a controller for the lower system before setting the upper system? Also, I can't find any info on why a check valve stops this trace and a PR does not? Am I missing something?
Thanks, Gavin
