This is the second time I have run into this problem, and not sure what is going on.
I was editing polygons in an existing shapefile when I saved it it said something along the lines of "number of shapes do not match records" and a few of the polygons that I had created had disappeared. I shut it down, and restarted ArcPro, and now the shapefiles won't load at all. Instead I get the following message:
Failed to open table.
Error:
Error creating map member.
This is the second time I have run into this problem. I originally thought it was because there were a lot of records within the shapefile (>20,000) so I clipped the shapefile to only include records I was editing. This seemed to work for a while until I got the message today.
Any ideas? This is the second time this has happened and each time I have lost about 3-4 days of work. My process seems to work fine until the 3-4 day.
