I am currently trying to use the D_Rename table in a UN Stormwater Asset Package (AP) to rename an existing asset group, Manhole Channel, to a new name, Junction Box, but am not getting a positive result. Below are the steps I followed to perform this update.
- Using the “Create Asset Package Rename Table” GP tool I added a new field and alias using the “Rename Fields” tool inputs.
- Next, I opened the D_Rename table and populated the new value of “Junction box” and then saved my edits.
- I then used the “Apply Asset Package” GP tool to update the existing AP with the new asset group name. To do this I updated the following options in the GP tool.
- Asset Package: Set to working AP
- Both Structure and Stormwater domain Networks were applied
- Rename using: Selected the new column that was created using the “Create Asset Package Rename Table”
- Input Utility Network: Selected previously created UN FGDB. Note: Network Topology had never been enabled in this UN.
- Load Data: I chose not to load data as source migration is still pending.
- After executing the tool, I received the following error.
- “Junction Box Subtype Code | description must be 32 | Manhole Channel.”
Can anyone provide suggestions into why this workflow is not working as expected? Are there any other possible options I could take to rename the Asset Group in the AP?
