Edited: This idea was previously titled "When tabbing through GP tool parameters, don't tab into Help tooltip".
ArcGIS Pro 3.2.1
When entering parameter values into geoprocessing tool parameters (such as in the Create Database View tool), I often use the TAB keyboard key to advance to the next parameter/textbox. However, if the next parameter has an "I" (Information/Help) tooltip, then the tabbing action tabs into the Help tooltip, rather than into the next parameter, which is cumbersome. I would need to hit TAB three times in order to get past the Help tooltip and into the next parameter textbox.
I think it would be better to advance directly to the next parameter. Could that behavior be changed?
Could tabbing into the info tooltip be improved?
Video:
