I have a form based on the Hydrants Inspection sample form that I've modified for my use case. The form seems to work fine for newly collected locations. However, I've populated the layer with existing locations that supply data to the main table but the related 'repeat' table contains no data. When I try to collect data for one of these 'preloaded' locations in the repeat for the inspection i get the following error:
@javascript error:TypeError: Cannot read property 'SIG_Det' of undefined in InspectionsFunctions.js:LastDetermination
This is coming from fields that use the following calculation in the form:
string(pulldata("@javascript", "InspectionsFunctions.js","LastDetermination",${CurrInsp}, ${PrevVisit}))
Script in the form that is causing an error is below. Data in the related (repeat) table get populated correctly. I am wondering if the error stems from there not being an existing value since line 3 of the javascript performs when there is a record in the repeat section but there is no 'else' to handle when (CurrInsp.length ==0).
function LastDetermination(CurrInsp,maxDate){
if (CurrInsp.length>0) {
var maxDateInspections = CurrInsp.filter(item => item.InspDate === maxDate);
var countOfInspectionsWithMaxDate = CurrInsp.filter(item => item.InspDate === maxDate).length;
var detOfMaxDate = maxDateInspections[countOfInspectionsWithMaxDate-1].SIG_Det;
return detOfMaxDate
