Does anyone know of a way to drag and drop CSV, SHP, and JSON files onto a map using the 4.x versions of the JavaScript API? I found this sample code for 3.x (legacy version - https://developers.arcgis.com/javascript/3/jssamples/exp_dragdrop.html) but I am using 4.x for all of my maps and would prefer to stick with that, if possible.
It doesn't necessarily have to be drag and drop, but I need the same functionality where the user can upload a data file (either CSV, SHP, or JSON), the data is read in and displayed onto the map.
This example I found works for zipped SHP files and uses the generate REST tool: https://developers.arcgis.com/javascript/latest/sample-code/layers-featurelayer-shapefile/. I tried doing the same for CSV files with some tweaking - it requires the Analyze REST tool to be run first to get the publish parameters and then generate for the feature collection (https://developers.arcgis.com/rest/users-groups-and-items/analyze.htm). I am getting a '414 URI Too Long' error from using the publish parameters (returns a very long JSON object) and not sure how to fix this.
Any advice is appreciated or if you have a better approach, please point me in the right direction.
