Hi all, I'd like to construct a SQL statement for a search cursor using a LIKE with a wildcard instead of an =...but I'm having some difficulty as I find SQL in python with all it's backslashes, apostrophes, double quotes and escapes to be rather confusing. I don't know where to put the wildcard "%" and how to escape it in the code...Here is what I've tried (couldn't get the script to work with "LIKE" but since I'm trying to find road names "LIKE" is necessary.import arcpy import os import re basedir = r"C:\Test" fc = r"G:\GIS\ParcelsPublic.shp" field1 = "ADD1" field2 = "STREETNAME" try: for fn in os.listdir(basedir): add = re.sub(r"\D"," ", fn) add = str.lstrip(add) add = str.upper(add) street = re.sub(r"[^a-zA-Z]"," ",fn) street = str.lstrip(street) street = str.upper(street) print (add + " " + street) expression = '"' + field1 + '"= ' + "'%s'" %add expression2 = '"' + field2 +'"= ' + "'%s'" %street expression3 = expression + " "+ "AND" +" " + expression2 rows = arcpy.SearchCursor(fc, fields="STREETNAME; ARN; ADD1", where_clause=expression3)
And this was provided to me on stackexchange but I haven't been able to implement a wildcard: expression3 = '"{field1}" = \'{add}\' AND "{field2}" LIKE \'{street}\''.format(field1=field1, add=add, field2=field2, street=street)
