Hope everyone had a good New Year.
I have the Water Distribution Data Management solution 3.0 which I use in ArcGIS Online and through ArcGIS Pro. In the past I have been able to edit the Domain Lists in AGOL but recently that option is no longer available. I have tried going through the json to do it as well and was not successful. I am trying to do things like add additional diameters for fittings, or a new asset type for a fitting etc. I have checked different layers and different fields within those layers and the option is not available for anything, even the ones I changed previously like Water Main: Owned By.
The only thing I can think that has changed is that I downloaded the Backflow Inspections and Utility Service Interruptions solutions (but have not started using them yet) to check out how they worked. Could some relationships be causing me not to be able to edit the domains?
Any insight or a fix to this without me having to download another solution, reload my data and re-do all my previous schema changes would be greatly appreciated.
