Wondering if I am hitting a limitation or what...
I am trying to Append Data from my AGOL site to my internal Oracle SDE DB
It seems to accept the sourceURL but fails targetURL
Is there an issue that I am trying to append to a Table and not a Feature Class....
any other thoughts?
import arcpy
import arcgis
from arcgis import GIS
gis = GIS("https://www.maps.arcgis.com/home", "username", "password")
currenttoken = gis._con.token
sourceURL = "https://services.arcgis.com/p5vkdfgdfgf/arcgis/rest/services/Inventory/FeatureServer/8?token=" + currenttoken + "sublayer=0"
targetURL = "Database Connections\\GIS_DEV@gis_guest.sde\\GIS_DATA.TBL_MS4_PermPaveInsp"
with arcpy.EnvManager(preserveGlobalIds=True):
arcpy.management.Append(sourceURL, targetURL, "TEST_AND_SKIP", None, '', '')
ERROR:
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Target Dataset: Dataset Database Connections\GIS_DEV@gis_guest.sde\GIS_DATA.TBL_MS4_PermPaveInsp does not exist or is not supported
Failed to execute (Append).
