When I convert a Web Map into a format I can use it loses as it's data.
I need certain enviromental data to use in MaxEnt but both the MaxEnt program itself and the tool available on ArcGIS require certain formats. MaxEnt requires ASCII and ArcGIS raster data.
I currently convert the web map using Share > share web map > to GeoTIFF > then use RSTUDIO to resize to the right extent. OR data >export raster. But both of these methods make the web map lose its attribute table and both programs are unable to use them.
How can I convert a web map properly so I can use them for analysis?
If this is not possible where else can I gain enviromental data for analysis? (I need the entire map of Europe)
Kind regards,
Marieke
