In an empty table in Pro 2.6.8, we can change the datatype of a field, such as from TEXT to LONG. But that only works if the table is empty. If the table has rows, then the datatype is greyed out in the Fields View, so it can't be changed using Pro.
In the back-end of a database, it's possible to change the datatype, even if the table has rows, as long as all the rows are null in that field. (It might even be possible for non-null fields too; I haven't checked.)
ALTER TABLE - ALTER/MODIFY DATATYPE
Oracle example:
--change a text field to an integer datatype
ALTER TABLE a_test_fc
MODIFY a_test_field INT;
But if I do that, the change is not reflected in the Fields View in ArcGIS Pro. I guess there must be geodatabase system table info that stores the original datatype; Pro isn't referencing the actual datatype from the database. (Interestingly, I'm still able to edit the data/field in the attribute table in Pro without issue; I can enter integers into the field. And of course, text values are no longer allowed.)
While changing the datatype through the back-end technically ran without errors, I wouldn't want to do that because now the geodatabase system tables are wrong. At best, that'll cause confusion for users, since the Fields View is displaying the incorrect datatype. At worst, it could cause errors in ArcGIS Pro.
Could ArcGIS Pro be enhanced so that we can change the datatype of a null field, even if the table has rows?
