I sometimes see the 'Send' and 'Save' buttons non-responsive.
Symptoms:
- The survey appears to work fine until you try doing one of the following operations: Send, Save
- Clicking the check-mark: 'Send now' and 'Save in Outbox' buttons do nothing after being clicked. 'Continue this survey' button works normally.
- Clicking the X: 'Save in Drafts' does nothing. 'Continue this survey' and 'Close and lose changes' work normally
- Closing S123 with the survey open and then re-opening S123 does not create a recovery file (It also doesn't fix the issue).
- Typically, only a full PC restart fixes the issue.
I feel like this is more likely to happen after waking a PC from sleep.
This really feels like some cyber-god is out to get you when it happens!
