ArcGIS Pro 3.2; file geodatabase:
When creating a database view in a file geodatabase, the view doesn't get automatically registered with the geodatabase. The user needs to do it manually using the Register with Geodatabase geoprocessing tool.
That seems like an unnecessary manual step that people often overlook.
As Esri Support said:
Case 03490768 - Database view on feature with nil geometry hangs when added to map
"Registering views with geodatabase also helps in resolving many issues related to views."
Can that behaviour be changed so that FGDB views get automatically registered when the view is created?
