When I search for an address, balloon appears to display that address. I would like the graphics to clear when I close the balloon. Below is the code with part of it commented out on how I thought I was supposed to do it. What do I need to change?
<!DOCTYPE html>
<html>
<head>
<title>Geocoder template</title>
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<style>
html, body, #mapDiv
padding:0;
margin:0;
height:100%;
#search
display:block;
position:absolute;
z-index:3;
top:20px;
left:75px;
</style>
<script src="http://js.arcgis.com/3.11/"></script>
<script>
var map;
require(["esri/map",
"esri/dijit/Geocoder",
"esri/graphic",
"esri/symbols/SimpleMarkerSymbol",
"esri/geometry/screenUtils",
"esri/geometry/Extent",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
"dojo/dom",
"dojo/dom-construct",
"dojo/on",
"dojo/parser",
"dojo/query",
"dojo/_base/Color",
"dojo/domReady!"], function (Map, Geocoder, Graphic, SimpleMarkerSymbol, screenUtils, Extent, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, dom, domConstruct, on, parser, query, Color
// declare initial map extent with spatial reference
var initialExtent = new Extent({ "xmin": 777229.03, "ymin": 1133467.92, "xmax": 848340.14, "ymax": 1185634.58, "spatialReference": { "wkid": 3435} });
map = new Map("mapDiv", {
showAttribution: false,
sliderStyle: "small",
extent: initialExtent
// begin geocoder
var geocoder = new Geocoder({
arcgisGeocoder:false,
geocoders: [{
url:"http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer",
name: "Web Address Locator",
placeholder: "Find address",
outFields:"*"
map:map,
autoComplete:true,
}, dom.byId("search"));
geocoder.startup();
geocoder.on("select",showLocation);
// dojo.disconnect(Geocoder,'onClear',function(){
// removeGraphics();
// function removeGraphics() {
// map.graphics.clear();
function showLocation(evt) {
var point = evt.result.feature.geometry;
var symbol = new SimpleMarkerSymbol()
.setStyle("square")
.setColor([255,0,0,0.5]);
var graphic = new Graphic(point, symbol);
map.graphics.add(graphic);
map.infoWindow.setTitle("Search Result");
map.infoWindow.setContent(evt.result.name);
map.infoWindow.show(evt.result.feature.geometry);
// end geocoder
// add imagery
var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
map.addLayer(tiled);
// set operational layers
var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
// add operational layers
map.addLayer(operationalLayer);
</script>
</head>
<body class="soria">
<div id="search"></div>
<div id="mapDiv"></div>
</body>
</html>
