I am updating an existing survey to add the field LOCATION_ID. It is connected to a hosted feature class and feature class view in AGOL. When I first created the field in the AGOL hosted feature class, I accidentally used Location_ID, but deleted it and readded it as LOCATION_ID. In Survey123 Connect, I have the field as LOCATION_ID. When I try to upload the survey, I am given the following message:
"Field LOCATION_ID in Utility Work Order case does not match Location_ID"
I tried deleting the row in Survey123 Connect, reuploading it without the field, then adding it back into the survey. I also tried deleting the field in the hosted feature class on AGOL, updating the view, readding the field, then updating the view again. I have closed and reopened Survey123 Connect and tried making it a text type instead of hidden, which is preferred. The only way it works is if I change the name of the field in both applications.
In AGOL:
In Survey123 Connect:
Anyone have any insight on why the case change is not being recognized? I haven't encountered this issue before and have been using Survey123 Connect for a few years.
