The Image Classification Wizard workflow text isn't super clear on whether the segments that are created in the first step of the workflow (if using object based, supervised classification) are used in the training and then classifier steps. There doesn't seem to be a way to explicitly ask the wizard to do this, if you're segmenting from within the wizard workflow. I would have thought the wizard just does this / flows on, but it's REALLY important I know for sure as I have done a whole lot of work on this assumption and if not I need to be able to say so... Thanks.
