클론 환경을 만들려고 합니다
그런데 이 오류만 났어요
도와주세요...
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\example. png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\header .tex
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\kwon gyeongwon\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\ IEEEtran.bst
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc \LaTeX_envs_menu.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\ doc\latex_env_doc.html
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs \doc\latex_env_doc.ipynb
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\ latex_envs\doc\latex_env_doc.tex
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions \latex_envs\doc\main_toolbar.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\ nbextensions\latex_envs\doc\README.md
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter \nbextensions\latex_envs\doc\Toggles.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\ jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_23_2.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone \share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_24_2.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro- py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_26_2.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs \arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_27_2.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\ latex_env_doc_41_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc \latex_env_doc_files\latex_env_doc_42_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\ latex_envs\doc\latex_env_doc_files\latex_env_doc_43_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter \nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_44_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\ share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_45_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3 -clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_46_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\ arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_47_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda \envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_48_0.png [I
17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_49_0.png [I
17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData \Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_50_0.png [I 17:48:44 InstallContribNbextensionsApp] 최신: C:\
Users\권경 won\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_51_0.png [I 17:48:44 InstallContribNbextensionsApp] 최신: C:\
Users \권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_52_0.png [I 17:48:44 InstallContribNbextensionsApp] - 검증 중:
ok
[ I 17:48:44 InstallContribNbextensionsApp] C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\etc\jupyter에 구성할 jupyter_contrib_nbextensions 항목 설치
활성화 중: jupyter_nbextensions_configurator
- 구성 작성 중: C:\Users\kwon gyeongwon\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\etc\jupyter - 유효성 검사 중... jupyter_nbextensions_configurator 0.4.1 ok 노트북 활성화 중
nbextension
/ config_menu/main...
트리 nbextension 활성화 nbextensions_configurator/tree_tab/main...
[I 17:48:44 InstallContribNbextensionsApp] 노트북 확장 활성화 contrib_nbextensions_help_item/main...
[I 17:48:44 InstallContribNbextensionsApp] - 유효성 검사 중: ok
[I 17:48:44 InstallContribNbextensionsApp] - 구성 편집: C:\Users\kwon gyeongwon\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\etc\jupyter\jupyter_nbconvert_config.json [I
17:48:44 InstallContribNbextensionsApp] -- nbconvert 템플릿 경로 구성
[I 17:48:44 InstallContribNbextensionsApp] -- nbconvert 전처리기 구성
[I 17:48:44 InstallContribNbextensionsApp] - 구성 작성: C:\Users\권경원\AppData\Local\ESRI\ conda\envs\arcgispro-py3-clone\etc\jupyter\jupyter_nbconvert_config.json
[I 17:48:44 InstallContribNbextensionsApp] -- 업데이트된 구성 파일 작성 C:\Users\kwon gyeongwon\AppData\Local\ESRI\conda\envs \arcgispro-py3-clone\etc\jupyter\jupyter_nbconvert_config.json
노트북 확장 기능 collapsible_headings/main 활성화 중...
- 검증 중: ok
복사 중: repr_style/main -> C:\ProgramData\jupyter\nbextensions\main
역추적(가장 최근 호출 마지막 😞
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Scripts\jupyter-nbextension-script.py", 9행, <module>
sys.exit (main())
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\jupyter_core\application.py", line 269, launch_instance
return super().launch_instance(argv=argv, **kwargs)
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\traitlets\ config\application.py", 982행, launch_instance
app.start()
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\ 노트북\nbextensions.py", 972행, start
super().start()
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site- packages\jupyter_core\application.py", 258행, start
self.subapp.start()
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\ site-packages\notebook\nbextensions.py", line 702, start
self.install_extensions()
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\ site-packages\notebook\nbextensions.py", 라인 675,install_extensions에서
full_dests = install(self.extra_args[0],
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\notebook\nbextensions.py" , 191행, install_nbextension
_maybe_copy(src, full_dest, logger=logger)
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\notebook \nbextensions.py", 1030행, _maybe_copy
shutdown.copy2(src, dest)
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\shutil. py", line 444, copy2
copyfile(src, dst, follow_symlinks=follow_symlinks)
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\shutil.py ", 264행,
open(src, 'rb')을 fsrc로 사용하는 copyfile:
FileNotFoundError: [Errno 2] 해당 파일 또는 디렉터리가 없습니다: 'repr_style/main'
노트북 확장 프로그램 repr_style/main을 활성화하는 중...
- 유효성 검사 중: ok
' chcp'\ufffd\ufffd(\ufffd\ufffd) \ufffd\ufffd\ufffd\ufffd \ufffd\u01f4\ufffd \ufffd\u073a\ufffd \ufffd\ufffd\ufffd\ufffd, \ufffd\ufffd\ufffd\ufffd\ ufffd\ufffd \ufffd\ufffd \ufffd\u05b4\ufffd \ufffd\ufffd\ufffd��\u05f7\ufffd, \ufffd\u01f4\ufffd \ufffd\ufffd\u0121 \ufffd\ufffd\ufffd\ufffd\ufffd\
ufffd \ufffd\u01b4\u0574\u03f4\ufffd.
반환 코드: 1
정리 중...
대상 폴더가 제거되었습니다.
