Hey, I have two shapefiles, one is polyline, the other is point (points correspond to both end of the polyline). I converted both shapefiles into KMZ files, it turns that the points do not line up with the polyline ends. The alignment is off by a couple of inch, while it shows perfect alignment in ArcMap. I used the exact same steps when converting (using 'layer to KML' in ArcMap). Any advice would be appreciated. Thanks.
