When I create a XY event layer from a sql table using the Make XY Event Layer in the Data Management Tools the Identify tool no longer works. I can't even select a single feature from the attribute table to identify. However, when I use Display XY to display the sql table locations the Identify tool works. Only problem with that is that the layer created doesn't update when the sql table is updated.
Am I doing something wrong? Is there a work around? Right now, I've been turning on the labels to identify the points, but that's not always practical.
I found a bug that sounds like the same problem but it's from 2017 and it doesn't seem that this has ever been addressed.
Unable to identify an XY event layer with the Explorer tool.
Last Published: August 25, 2017
ArcGIS Pro
Bug ID Number BUG-000107226
Submitted August 9, 2017
Last Modified October 14, 2020
Applies to ArcGIS Pro
Version found 2
Operating System Windows
Operating System Version 7.0 64 Bit
Status In Review
Bug ID: BUG-000107226
