I have a hosted feature layer which has been published from Survey123.
CRS WGS84
On attempting to manually backup this layer (Export to FGDB) the export fails with a generic error. Shapefile didn't work, KML worked but had empty output. non spatial formats worked OK, CSV, JSON etc.
On inspecting the JSON I could see some strange coordinates which may be causing the issue.
I'm in the UK so the Lat Longs will be something like' -2 , 52' all the records show coords around this so nothing stands out. The obvious exception is a record in the layer which has coord values of of '-260,000 , 52'
1. Does anyone have an idea how this could happen from a survey submission?
2. Also is this a Python/Rest API fix or am I missing something obvious to do to fix it in the AGOL GUI?
Any comments or suggestions at all are much appreciated.
