Please add the ability to use multiple field symbology in web map viewer.
Currently, if you want to use two (or more) fields for your symbology, one has to be text and any other numeric.
The only two workarounds are
1. To create an arcade expression that returns a numeric value, thus changing the size of the point. (color from text and size from number)
2. make a map in ArcGIS Pro using two fields and upload it as a web map. Using this method will NOT let you later change symbology in AGOL and any changes would need to be overwritten
The current way of using two-field symbology and the workarounds limit the way we can use symbology online.
