I have a point feature class (BUS_STATIONS), and an M-enabled line feature class (ROADS)
We are trying to build an attribute rule on the BUS_STATIONS feature class, that would populate a field with the M-value of the nearest point of the road. NOTE: I don't want the M-value of the nearest vertex (which could be far away) but rather the nearest portion of the line. What I was thinking to do was the following:
1. Find the coordinates of that nearest point (not vertex) on the line
2. Then find the M-values of the vertex before and after that point and calculate the M value.
But right now I'm stuck with step #1. Any ideas how to achieve that?
Thank you
Chaim
a point feature class, that will populate the M value of the nearest li
