I want to extend an existing line by a distance in the same direction. That is, after the edit, I will have two line segments, both in the same direction with one point in common. A use case for this is a land survey where a straight line goes into the property of a different person, so the distance in one property is stated separately from the distance in the other property. I'm doing this interactively.
