LocatorTask.ReverseGeocodeAsync has a method that takes a parameter that has ReverseGeocodeParameters.MaxResult that the documentation says the WorldGeocodeService can return up to 20 results per request. The return value of this method is an IReadOnlyList of GeoCodeResult. This leads me to believe that I can request more than one hit within a radius.
However, looking at the request through Fiddler, the maxResult is not passed in the request parameters. The documentation for the Rest API for reverseGeocode doesn't indicate that the result can ever be a list of addresses, or that MaxResult is an available parameter. Is there a mismatch between the implemented SDK API and the REST API, or is it more future proof?
We have many configured Geocode services (doing direct query against featurelayers is rather cumbersome as everything is ideally supposed to be configured in the portal. We want to query "What's near this location?", and we need multiple results per service as the MaxResult property says.
Are there good workarounds for this, or alternative geocode API? findAddressCandidates (LocatorTask.Geocode, I presume) with location might be an option, but I've not seen samples on how to send just a position to get multiple addresses, but that could be a combination with SearchArea and some additional parameters to get within a radius?
