ArcGIS Pro 2.6.8; Oracle 18c; 10.7.1 EGDB; versioned (with the option to move edits to base)
As far as I can tell, it isn't possible to Select By Attributes using a SQL expression that references the SHAPE column:
Whereas, it is possible to do it in a definition query.
That seems like an oversight. We should be able to query the SHAPE column, such as WHERE SHAPE IS NULL. And more complex use cases.
Could that functionality be changed?
