We make extensive use of HTML Windows and ArcGIS Earth Automation API in our organisation.
When a user closes ArcGIS Earth, the position of the HTML Windows (in pixels) is automatically written in the html_windows.json file (...\AppData\Roaming\ESRI\ArcGISEarth). Everything works fine as long as the user stays in the same environment.
But users tend to switch between 2 workstations nowadays : home and office. When a user switch between these two environments, it is common to see that the HTML window won’t open anymore. (I believe it is because the display parameters are different : number and/or size of screens differ.)
Right now, to correct the problem, we have to :
- Remove the HMTL Windows
- Close and reopen ArcGIS Earth
- Add the HTML Windows again
Is there a way we can mitigate this problem ?
Thank you.
P.S. : Right now, we are still using ArcGIS Earth 1.18.
