This may have already been suggested, but it would be a game changer if we had more customisability in setting up/creating new pro documents. Instead of the 2 options we get now (which folder to save new pro document in and what to call it) it would be helpful to be able to customise:
- What to call the pro document (.aprx)
- Where to save the document OR whether you want a new folder created
- What geodatabase you would like to default OR if you would like a default geodatabase created
- What toolbox you would like to default OR if you would like a default geodatabase created
Ive worked at a few places now and the layout structure preferred is 1 single GIS folder per project. It is also preferred to have 1 map/plan per pro document, as saving multiple maps/plans to the same pro document can be hard to keep track of and can result in a very slow experience on the pro document. Its getting very messy having a new folder, gdb & toolkit created for each map/plan, and then it messes with the links when you then try to cut and paste pro documents to different folders. Therefore having more customisability to allow multiple pro documents to be saved under the one folder, like how it can be done with mxd's would be super helpful!
Thanks!
