Hello everyone! is it possible for any of ArcGIS Dashboard elements to reads from more than one layer (Data sources) at the same time?
Thank you!
Hi @NasratullahOmari
Thanks for your question, would you be able to provide some more information on what you are trying to achieve?
Many thanks!
Issy
for example, I want that my indicator element read from two reference layer (data source), so is that possible? Thanks
Why don't you use a data expression and you can combine the two data sources there into a single dictionary. If you're just interested in one field, you can just specify that in your dictionary.
you can have a look at this: https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/CombineMultipleLayers(SerialChart).md
I hope this helps.
Thanks @MlondiNdlovu1 . Yes, this is helpful for someone who knows about the data expression and Arcade.
