I have a survey created using Survey123 connect on ArcGIS Online.
I select city from list in the 'choices' tab, and have to select station, from feature service table, filtered by that city.
The ${CityName} column has a domain value, that is Integer and label as string.
I use autocomplete search:
autocomplete search("STList?url=https://utility.arcgis.com/usrsvcs/servers/xyz/rest/services/Servicename/MapServer/1","matches", "CityCode",${CityName})
I've created the survey a long time a ago and it worked perfect! Few months ago it stopped filtering the list.
When I check the survey in browser and F12, I see that the rest query created contains:
(name IS NOT NULL) AND CityCode = '182'
The column is integer and the filter value is string, so the query fails!
In XLSX the CityName is defined as esriFieldTypeInteger, so does the column CityName in the survey feature service, and in the table feature service for the list.
What causes the survey to create string value, how can I change it.
Thanks for any help
Ofra A
