Hi
I have a survey created in survey 123 connect (3.18.124). The survey is using Search - Matches in the appearance of a select one question to pull a list of addresses based on a task ID pulled from Workforce. It also uses pull data to retrieve other data such as Unique property number.
As soon as I add the csv file containing the addresses with corresponding ids the survey reloads and gets stuck on Loading Survey......
There are around 40,000 addresses in the CSV.
Is this beyond the limit of survey 123 or should it be able to handle the csv, in which case where am I going wrong 😕
