I've used Data Expressions in dashboards in AGO quite a bit in the past, but I'm not certain how to do so in Portal. We use Windows Authentication to login to Portal, but I can't figure out how to use the FeatureSetByPortalItem function to return the item without having to pass in credentials. I would like to just reference the Portal URL, then the item id, then have it return the feature. How do you work with data expressions in Portal?
