Can somebody please show me an example of how to use the bind::esri::warning column for a warning message on a geopoint question in Survey123 Connect? There are tons of examples out there for using constraints on a geopoint question - which I know how to implement - but I can't find a good example on a warning without having to use a note question type and the relevant column.
From what I've read, you can use the same expressions you would in the Constraint column in the Warning column, however, when I try that nothing comes up as a warning in my survey after published.
Any help would be great.
Thanks!
