Hi Community,
I am trying to do a simple task in which I would like to view the pop-up of features when clicked on it using ArcGIS Maps SDK for JavaScript. I came across the following link https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/defaultpopuptemplateenabled-not-working-with/td-p/1054565 which suggests to add the following line : view.popup.defaultPopupTemplateEnabled = true;
However, when I am trying to do the same in my code, there are no errors however, when I click on any feature it just gets highlighted and pop-up doesn't open. Am attaching the code here.
The layer on which I am running this code is a hosted feature layer published via Survey123 to ArcGIS Online
Am not sure if I am missing something here.
Any insights on this would be really helpful.
require(["esri/config", "esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer"], function(esriConfig, Map, MapView, FeatureLayer){
esriConfig.apiKey = ""
var map = new Map({
basemap: "arcgis-topographic"
var view = new MapView({
map: map,
center: [77.18108, 28.53337],
zoom: 15,
container: "viewDiv"
const floralayer = new FeatureLayer({
url: "xyz",
map.add(floralayer)
