Hello everyone,
I am trying to connect a PostgreSQL server. The initial connection process goes smoothly, and I can successfully add the connection under the database connections. All tables are populated from the PostgreSQL database as expected. However, I encounter an issue when trying to add the data from the connection to the map; ArcGIS Pro becomes unresponsive and freezes. I am unable to cancel the operation or interact with the software.
I tried the same process with data from my local PostgreSQL connection, and it worked without any problems.
Thank you for any insights or assistance you can provide.
